Upstream information for streams ingressing on spb-multicast interfaces
Upstream information for streams ingressing from a remote SPB node
Receivers in spb-multicast interfaces
Use the show ip spb-pim-gw mroute command to display information only on SPB-PIM Gateway interfaces.
![Note](images/note.png)
The show ip spb-pim-gw mroute command displays active upstream information and active downstream information per (*,g) and (s,g) per port, which includes *G Join or Prune pending state, SG join or prune pending state, and SG Rpt PRUNE or PRUNE pending state.. There can be upstream information for a specific SG and no downstream, and vice-versa, as the information in the command show ip spb-pim-gw mroute reflects only information known on the SPB-PIM Gateway interfaces. For example, there might be downstream receivers on a SPB-PIM Gateway Interface for a particular stream which is ingressing on an spb-multicast interface; thus, the upstream information will not be displayed using this command.
Switch:1>show ip spb-pim-gw mroute ============================================================================= Spb-pim-gw Active PIM Multicast Route - GlobalRouter ============================================================================= Src: 0.0.0.0 Grp: 225.1.1.1 Flags: WC Joined Ports: Vlan Ports Join Timer ---- ----- --------- Vlan30 1/3 155 ----------------------------------------------------------------------------- Src: 123.1.1.101 Grp: 225.1.1.1 Upstream: 50.1.1.1 Incoming Port: Vlan50-1/5 Flags: SG SG Joined Ports: Vlan Ports Join Timer ---- ----- --------- Vlan30 1/3 184 SG Prune Pending Ports: Vlan Ports Prune Pending Timer ---- ----- --------- Vlan40 1/4 180 SG Rpt Pruned Ports: Vlan Ports RPT Prune Timer ---- ----- --------- Vlan90 1/9 156 SG Rpt Prune Pending Ports: Vlan Ports RPT Prune Pending Timer ---- ----- --------- Vlan60 1/6 164 ----------------------------------------------------------------------------- Total Num of Entries Displayed 2/2 Flags Legend: WC=(*,Grp) entry, SG=(Src,Grp) entry
Variable definitions
The following table defines parameters for the show ip spb-pim-gw mroute command.
Variable |
Value |
vrf WORD<1-16> |
Displays the SPB-PIM Gateway mroute information for a specific VRF name. |
vrfids WORD<0-512> |
Displays the SPB-PIM Gateway interface mroute information for a range of VRF IDs.
Note:
Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘. |
group {A.B.C.D} |
Displays mroute information specific to a group IP address. |
source {A.B.C.D} |
Displays mroute information specific to a source IP address. |
